Engine has left the car now the fun
...Begins:sweatdrop:
Will take some pics later..........god it looks awful with the engine out:no:
Needs a nice spring clean, whats the best cleaner to use on inner wings etc.
Dave
Stu if you read this is there any little jobs you think may need doing that you never got around to:blush:
Edited by yewcheck
  • Replies 43
  • Views 1.9k
You gonna sort out front front styling?
Give me a bloomin chance:biggrin: want to sort oil leaks and other little issues first.
Working from inside out:blink: still un decided about the front at the moment may just try the front panel first.:thumbup1:
I'd imagine the picture would look very similar to this :)
In terms of Jobs to do. I pretty much did everything I could think of at the time. I had almost a year with the car and no engine so had plenty of time to play around.
All I can suggest is a good clean and maybe a tidy up and inspection of the wires/ looms/pipe and a good wash judging on how the engine bay looked the last I saw it.
:yes::yes:Looks familiar :whistling: in a past thread you mentioned that you had a similar prob with manifold blowing am i right:wink: and if so was it the o/s one?
Manifold?
Not me Dave, The only thing blowing on that car was the turbo.
Never had any manifold issues with it myself.
Manifold?
Ah thanks buddy read it wrong:thumbup1:
When i got you, can you remind me again what you did for fog lights?
as i said the red switch where cruise usually is has been disconnected! spoke to leigh he said not down to him!!
Is it just a case of finding a wire from the rear light clusters that you poss ran and follow it back to switch:blink:
Pics, whats the thing in the last picture? i need to replace it due to connector breaking:crying:
oops lol,
thats your AC fast idle control solenoid
A/C is that air con? cause i kinda dumped that!
Congrats matey, did the gear box trick work? by the looks of it, it did. Nice to know a bit of advice helped someone else out.
yep, its for the air con, only raises the idle when the AC is being used so, if you've junked it, it dont matter :D
Worked a treat mate, hope it goes in easier than it came out though:sweatdrop:
Thanks to all that helped me in this little project,don't go anywhere will need you when it going back in:clown:
Dave
:) if you dont touch the cluth housing, friction plate, and flwheel, it should just slide back on, if you want ill pm you my number, if you get stuck, just ring
Clutch is knackered mate got to source a new one:no:
One thing you may be able to help me on i need a hose but to be honest wouldn't no how to describe it is there a diagram about with all the hoses
What sort of area is the hose in?
Is it water, oil or air ?
Have a look on courtesyparts.com as they usually have diagrams of exactly where the hoses come from and the part numbers of new ones that you can use to order from MJB in the UK.
Top left hand side [looking at engine] Stu, going to look at it lunch time.
Funny enough i was looking on courtesys site a few moments ago but cannot identify part!
Dave
Dave
Top left - if its one of bigger hoses then it will be the Clutch or Brake booster pipes.
I think it connected like this, looks like it did from memory
Edited by yewcheck
Brake booster/servo pipe, MJP/Nissan or put a wanted post up, Im sure somebody will have one of a breaker.
Cheers Dave:thumbup:
has anybody got a picture of the engine with all the belts on please need to varify something:oops:
