You need to remove the big trim that surrounds the clock/stereo etc, theres a plastic strip above the stereo that you remove as its covering up some screws, also in the top corners theres some little black plastic covers that need popping off and again theres screws under there. Pull the trim back, unscrew the clock from the trim, remove the electrical plug and refit. Your new clock should be with you wednesday :thumbup:
