Without removing my engine is there a way......
asked jeff to do the exact job on mine when i had a belt change the other week...motor out to do it right
:censored::headvswal oh well at least i can probably sort oil leak at the same time
You can do it with the engine in, but as mentioned above to get it done right and reduce risk of it happening again then it's an engine out jobby.
Saying this you have GD manifolds on that which stick out a bit more than standards so theres even less room. I don't believe you'd be able to ge the manifolds off fully without the engine out. Also make sure the blts are kept in the correct order as one of them has beeen modified to fit with the GD downpipes.
Thanks Stu
Would i need special gaskets for the down pipes???? and if so where would i get them????
