could i have a boost/vacuum leak??
- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
if my boost gauge boosts fine straight up to +7 and stays there while accelerating hard, does that mean i have no boost/vacuum leaks or could there still be a leak somewhere?? my idle is a little rough, checked a few connections, seem fine, the yellow temp sensor brings the very front fan on when i disconnect it then goes off again when reconnected so that connection seems ok, maf disconnected increases the rpm so that seems to be working ok, put new plugs in and had the throttle valves cleaned. will try an ecu diagnostic tomorrow to see if any codes are registered. where is the tps?
