door handle removal???
ive finally managed to get the door card off but whats the next step for taking out the door handle and swapping it with a new one?
search button is your friend - check "interior door handle" and there are loads of threads on replacing handles etc.
I would post a link but i don't know how.
Are you replacing with chrome ones - if so well done, they look much better.
Also check the following link to website - very useful for lots of things zed relater - all with pics :thumbup1:
should have clarified, its the outside handle i need to replace, someone tried breaking in to it when it was with its last owner and its never been replaced.
found a good link after a while of searching, looks like a real pain though! estimated 2 hour job to swap over a door handle!!
Outside handles - check this then bud:
http://www.ttzd.com/home.html
Go to the bottom of the page there is a link to door handle and lock removal - Like you said its a bit of a mission.
Little buggers, trying to get in your car - least they didn't smash the windows in. :2guns:
Outside handle is quite tricky. Basically you have 2 nuts that secure it to the door skin. One is accessable quite easily, the other, you need to pop off the little grey plastic blanking plug. Stick a small deep reach in there and unscrew.
To pull the handle off, you pull out the bottom part and gradually lift it upwards (from the forward part of the handle). Lift it right up (pivoting it from the back of the handle) and it should pull out. Refit in reverse. It is tricky....and also quite difficult to explain.
its not as hard as it looks. Study the rods and how they are sat first and make sure everything is in the right position when you put the new one back in or it wont work right!
Yeh well said Baz, I always take a load of pictures on my camera before starting work, and then you can check later if its all back together properly:cool3:
Daz
little piece of advice, if your removing it run some masking tape around the handle before your remove and re-fit your new one, just incase your scratch the door, it can be quite tricky getting it out and last thing u want to do is have to paint or touch up things!
hope this helps
cheers guys, got there in the end, hope i dont have to do another one any time soon!
