In memory of Mandy
Flashing dash warning light
What does it mean......its red and well hard to describe.. its below temp gauge and is a red box with line each side and a heat haze symbol coming off it!
  • Replies 58
  • Views 1.5k
Any other Issues mate, don't be afraid to call.
I know when you are trying to get things sorted and get stuck it's fustrating to have to wait for a couple of hours to find the answer. If you ever get in this position give me a call and we should have you sorted in a couple of minutes.
Thanks Stu
Much appreciated answers, will keep you posted on the jobs i am carrying out only if you are interested:blush:
Do not want you thinking the car has became a shed! its in safe hands;)
Thanks Stu
Very interested mate. Always good to see the cars your've previously owned and how they have changed / are changing.
Great will do!
One other thing i will be removing engine as you prob read, what effect will this have on the alarm and boost controller due to battery being removed for x amount of time?
Dave
Great will do!
Dave
Oh and radio code!!!!!
Back on topic been fiddling :oops: seems this light reacts withe handbrake!
When the handbrake is on no probs with light, as soon as you release it light starts flashing any clues??
Light - Check the handbrake cable is not pulling at the Cat sensor.
Radio - Code should be written on the paperwork. I've no clue what the code it :(
Electronics - The boost controller will probably need to be set up again. I would take a note of the settings etc, before you pull the plug.
Alarm - not an issue if you have saved the setting on the laptop, you can just plug this in and upload the settings when you are back on line (same with the traction control).
O for fook sake all unplugged and dead in the water:cursing:
Where can i get this set back up then:no:
