looks like a injector connector on the main engine harness, have you recently done a engine change / plenum pull? or something else recently?
OMG you mean its alive!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Well done John, how does it sound? have you taken it for a spin yet?
I am really pleased for you..
Sounds very loud need to fit the exhaust. If it get time will drive it out and sort the garage out, underseal then fit them. But need to get a alt belt 1st then I can fit the rad.
How did you get on this weekend?
Well since friday...
Undersealed the inside of the boot, we ran all the audio cables through the car, along with the new fog light wiring. Routed the NOS feed through the car and the bulkhead. Put the dash back in (apart from a broken cluster bracket). Test fitted the double din centre console. And I relocated the power steering resovoir and heated and bent all the connectors so it sits next to the brake servo.
I am now sort of ready for the interior to come back so I can start fitting that.
Almost every piece of plastic trim is broken or cracked in one way or the other.. its a pain in the ass.
I am hoping to get the engine in the car in the next few weeks with a bit of luck.
Sound like you have been busy..
Will make a start on your boxes next week now i can get the zed moving.
No rush John sort your own car out first, we just needed to get the cables in so when the interior comes back from the trimmers I can put that it. I think im gonna need the engine lift back for next weekend if possible though so I can put the flywheel etc on.
