Evo 6 brakes and 330mm discs
Hi all, i have been offered some brakes of an Evo 6. I know the calipers would fit with a braket but i have also been offered the 330mm discs. Would they fit??
cheers
[sIGPIC][/sIGPIC]
so nothing would fit or just the discs won't. cheers
[sIGPIC][/sIGPIC]
Sorry bud. The discs don't fit as they don't go onto the hub I can't quite remember why m8. The 350z discs go straight onto the hub. I also used the evo brakeline from the caliper to the car. There is a thread about the brackets that's less than a week old for a chance for you to get a set. I would search but Amon phone bud.
if its the centre bore that doesnt fit on the hub, surely just take it to a maching shop to bore it out some more (if the Disc bore is too small)
  • 3 months later...
Ok then got the set:clap::clap::clap:
Got them off the lad Friday. The disc size is only 310 though. So would i still be with the same problems even though the disc is smaller.?? cheers
[sIGPIC][/sIGPIC]
Hi Mark,
Good to speak with you earlier this morning.
I've not been able to get hold of the chap who made Rob's brackets for me but will continue to try.
I've just had a quick look at the specs of the EVO 6 and EVO 8 discs and in both instances it would appear that the centre bore is 69mm (versus 68mm for the Z32). However, the disc diameter should be 320mm (not 310mm) and the thickness is 32mm. The height of the disc is 43.5mm (versus 54mm for the Z32) so as you can see on many different accounts the Evo discs won't fit the Z32 hub.
You are probably best off buying a set of DBA 4000-series discs, either for a 350Z (£378.00 + p&p) or GT-R33 (£350.00 + p&p). Both are as close as you'll get to the EVO 8 discs and are 324mm diameter, thickness (30mm) and have the correct mounting PCD and bell height.
In any case, I'll get back to you regarding the caliper bracket work and we can discuss disc choices at that point.
All the best,
Cheers Danny for that. Now i have the figures it looks like new discs.
[sIGPIC][/sIGPIC]
