Silly questions from a newbie
- Replies 28
- Views 1.2k
- Created
- Last Reply
pbryant_knight 10 posts
ck300z 4 posts
Trevz 3 posts
Gaz 300 2 posts
HI All,
Just joined the forum and bought my first 300zx over the weekend and have a few silly questions that i'm hoping someone will answer.
It's a 1995 300zx fairlady Z with an Auto gearbox.
1- the Auto gearbox has a red plastic peice at the front? what's this for?
2- next to the gearbox is a button that says Power at the top and Hold at the bottom? What does this do? Bear in mind, i've just bought the car and didn't really want to press it not knowing what it did in case you have to do it at a certain time ie: before you engage gear.
Changing gears. In an auto normally you can change down gears manually to gain more power to overtake etc. With this car, the Overdrive button is located on the side of the gearstick and when you push it in a light appears saying "overdrive off". Is it ok in general to turn the O/D off to over take the press it to turn it back on when your done? (like changing from 4th to 3rd gear then back again)?
I realise these questions may be really silly to a bunch of hardened ZX owners lol.
Peter
