Hi everyone! had problems with my zed missing/ cutting out when going from high revs to completely off the gas. changed the fuel filter, stripped down and checked the loom, cleaned up or replaced all the connections, checked the timing and it run perfect. then stopped for fuel and it started again. think its just down to not having any clips on the injector plugs and there vibrating loose?
hears the thing, when its missing i get a lot of wobble from the steering wheel under braking which wasn't there when it was running properly.... any ideas????!!
Problem no. 2, the fan in the roof runs with the ignition off, draining the battery, took it out but somthing is still live, is anything else on that circuit? going to have a look at the head unit as i fitted it when it was off road for a bit but apart from that im stumped. please help im going mad.....er trying to sort this out. :cursing:
Cutting out and rough idle I would check for boost/vacuum leaks first, is it using more petrol than usual ?
should have said its an N/A. checked it over and no vacuum leaks. it is drinking more than usual yes.
