I intend to connect supply to ballast box from original bulb connector, That right [please confirm ]
What to do with the black wire that is left in Headlight when you remove old
bulb? Its a swiched negative , Just leave ?
Last ? You guys who fitted H I D conversion, did you need to have lights
set up again , to avoid dazzel?
Thanks for help on this upgrade
bulb
The black wire left is the old earth/ground for the oem bulb. Its no longer used.
The in of the ballast connects to the existing wires that went to the bulb and the out goes to the HID bulb.
So the four wires in the rubber grommet/seal to the headlight, pull the 2 wires, black and red with the spade connectors through the rubber, so you are left with the 2 wires to the new bulb otherwise you wont get a tight fit using the original ring collar.
The 2 pulled wires connect to the original bulb wires outside of the headlight.
Really easy and straightforward. You shouldnt need to re angle but you may need to clean the lenses.
Graham
As above BUT I would strongly recommend you drive to your local MOT station/friendly garage and have them check the alignment of your headlights. Because the HID bulbs are longer than the OEM halogen bulbs you MAY find that the beam pattern has shifted and requires adjusting. I ALWAYS recommend my customers to do this just to be sure. Shouldn't cost more than a fiver if anything at all. You should also ensure that the INSIDE of the projector and headlight glass are clean as dirt will cause excessive light scattering and blur the beam pattern thereby making the HID lights less effective and possibly blinding oncoming traffic due to glare.
