AEM boost gauge any good?
Dont know if it`s any good, but looks really easy to operate and a great idea!!
I have a boost controller now that I want to replace, nothing wrong with it but I have an AEM Map sensor and engine management gizmo.
I can't see ebay links through work, but if that is AEM's boost gauge and boost control?, then yep it's pretty good.
However if you have a AEM ECU that your fitting, that also has boost control in it, built in already if you want to use it that is, though the above gauge/boost combination is easier.
smithy
Cool just bought it along with an oil pressure one and with my Map sensor one will be three of them. Could do with a water temp one as well but no where to put it!
Yes my mate has one, swears blind by it! very good system apparently :thumbup:
The Map sensor one i'd fit in the glove box, not unusual to see some gauges in there that arn't always looked at.
Water temp is important though as the stock one is absolute crap and at the power your gonna be running, you wanna know she ain't getting too hot!
smithy
ummm you are probably right did not think of that, I might do that, I was thinking about fiberglassing my own 4 pod configuration when I put the audio in as well.
