hi there!
my name is Lucio have 24 years old, and the car over here is a Z32 TT 2+2
:thumbup1:
  • Replies 44
  • Views 2.5k
Welcome to the forum mate, get some pics up of your Z, you will need to use a hosting site like photobucket to show the pics though
Chris :)
Chris :)
hi here is the list of mods and some pics :)
hello there is my list of mods and a few pics :laugh:
stock engine 141500 km
T-304 Stainless Steel Exhaust sistem
2.5´down pipes
2.5´ test pipes
2.5´ cat backs and 4.5” tips
SZ chip
dual intake
Unorthodox racing pulley
BilZki overdrive water pulley
AMZ stage 2 turbos
Manifolds upgrade ( ebay AMS )
blitz SBC i-d III spec R
NISMO 555´s injectors
crome aluminiun hard pipes
slicone hoses
nismo radiator cap 1.3 bar
NGK iridium IX ´8´ heat range
ebay short shift
Z1 motorsport dump valves
magnetic engine oil drain plug
godspeed SMIC´s
CZP EGR off kit
full energy suspencion kit
AMS o2 sensors
XTD 6 puck clutch
XTD flywheel
SS clutch line
CZP chromoly clutch pivot ball
CZP silicone brake booster to check valve
CZP silicone brake booster check valve to plenum
CZP silicone clutch booster check valve to plenum
Nissan OEM 300ZX rear transmission seal
Nissan OEM 300ZX rear main seal
Nissan OEM 300ZX throw out bearing sleeve
Nissan OEM 300ZX throw out bearing sleeve spring
Nissan OEM 300ZX withdrawal lever fork spring
Nissan OEM 300zx fuel filter
Nissan OEM 300zx rear main seal retainer gasket -
300 degree 300zx flywheel stop tool
NIssan OEM 120k timing belt kit
Rameyz studs
1pc AMZ drive shaft
SL55 AMG fuel filter
4 new slotted rotors and EBC red stuff pads
SS goodridge brake lines
edge racing dual intake
Motul 300V 15w50 engine oil ( change every 3000 miles )
redline MT90 oil gear box
shell axle oil to the dif 80w90
Glycol Shell for cooling sistem
some pics
hope you like :D
more mods to come soon :)
you forgot to put pic heavy lol
What power is she?
lolol
i did not have done a dyno to test the new turbos, but is the first thing to do whem the weather condicions get better :)
Why did you plant a tree in your engine?
lollol i not plant the tree in the engine
the tree is in the left side of the car :yes:
