AfterMarket Radiator
If i was to fit an aftermarket Rad can i still use the stock/carbon fan cover because i think it looks pants without one. I also want to keep the original fan.
one more thing can you still use the original rad pipes???
Yes ive got an uprated radiator and the rest still fits
Marty
Marty
Have you got a pic mate?
Ill take one later on mate just give me a nudge if i forget but my rad has the 2 threaded holes at the top for the fan guard and the pipes coming off the rad are the same diameter and angle to accept the coolant hoses.
some you can,some you cant
I have a koyo on the t/t and you can use the fan shroud,you may have to trim the top radiator hose slightly if you go a thicker radiator
Hi Dave sorry it took so long but this is mine with the shroud on fine. I have a larger radiator from ebay that has threaded holes for the top 2 bolts for the shroud cover. Also i had to cut the top coolant hose slightly to fit on the wider radiator.
Marty
Marty
looks good to me mate ta very much :cool3:
