What autobox fluid
Sill question and ive done a search but cant find anywhere what fluid the autobox uses Dextron atf 2 or 3?? as i have seen both on the shelf??
anyone?
Thanks Craig
Edited by ZX-TT
i use/got the lucas atf fluid from dukeries engineering for my autobox, great service highly recommended
http://www.dukeriesengineering.com/www.dukeriesengineering.coms/info.php?p=7
ID: 10052x12 Sure Shift Semi Synthetic ATF Case Of 12 Bottles
Lucas Semi-Synthetic Automatic Transmission FluidDesigned to withstand high temperatures and pressure. Excellent for high performance transmissions. Greatly extends transmission life and fluid life in truck and passenger car use. A real money-saver.
This is no normal ATF formulation. It has been developed to give the smooth, precise shifts needed by ET racers and yet extends a degree of protection not found in any other ATF. This product will stop wear and tear like nothing you've ever tried.
Key Benefits
Smooth, precise shifting
Extraordinary protection
Prevents wear and tear
This sale is for a case of 12 x32oz (0.95litre) bottles
Price: £45.06 (ex vat) £52.95 (inc vat)
Cheers for that chap, was just looing for standard stuff to top mine up as ill be going manual very soon I have some dexron atf 2 at home just not sure if i can use it???
for the money i reckon its worth chucking in a bottle of the lucas stop slip when changing over the fluid, dont overfill the box of course, did my change on the driveway with engine running and in gear, its a fiddle at first but then very easy, you have to chock the wheels and have handbrake on of course...pull off the gearbox feed line that goes to the cooler/rad and point into a large deep tray (fluid comes out with some speed so be careful)....as you run in gear the old cr@p will flow out at the same time keep pouring the new in through the filler pipe....you'll see the colour change after a few bottles and know you have replaced all the old with nice new fluid etc...ideally get a mate to help :D
aha just saw your post...ok well any atf from motor factors will do most will exceed dexronII etc
Might see if Jeff has time while im at zedworld on saturday
Either dexon 2 or dexon 3, all are compatible and Dexon 3 superceeds Dexron 2, which superceeds the Dexron (1) specified by Nissan.
Edited by Yowser
cheers for that ill top it up later
Good tip!!
I'm doing mine soon.
Cheers!
Andy
We flush our boxes on Mercs this way as they suffer from the torque converter juddering due to contamination - this sorts them out & makes the box change so much smoother!
Well worth it IMO :thumbup1:
ha....yours isnt even on the road Paul...:p
its on a very nice ramp tho!! :crying:
