gtr disc fitment....
Hey people,
If i fitted GTR front Brembo calipers, (with appropriate brackets) could i fit the discs too (are they the same fitment)?
Cheers,
Al. :biggrin:
If you fit GTR R33 or R34 calipers then yes you can just fit the 324mm GTR disc.
Also note you will NOT need any relocation brackets, but if you get the R34 calipers, the hub mounting holes will need enlarging to 14mm and you will need to get caliper mounting bolts as well.
R33 calipers have the same 12mm hole.
Have you got some GTR calipers already? Which ones?
Not got them yet, still searching. Looking to get the r33, r34 gtr calipers or the evo 8 or 9 calipers. Will let you know when i get them.
Just needed to be sure the disc is the same fitment. (for the gtr calipers)
Al.
The GTR calipers are bolt straight on, no brackets, and you must use GTR spec Discs (stock or aftemarket)
350z Calipers are the same spec as GTR Calipers, but use a different is offset, so require 350z spec Discs. The rears however do not bolt staight on.
The Evo calipers are larger, but require custom brackets for fitting.
Is the front evo caliper offset the same as the GTR offset? (Same disc)
Al.
If I fit caliper relocating brackets to my stock calipers - do i use GTR discs or 350Z discs?
350z discs matey, GTR discs are a direct replacement when using GTR calipers. Also, don''t go for the EBC disc, imho.
Al.
I knew you would be along soon, with your infinite 300zx knowledge. Very well corrected matey, cheers :)
Al.
It depends on which relocating brackets you got, they differ between the GTR ones and the 350Z ones, simply buy discs for the brackets you have.
That said 99% of relocating brackets on here are GTR fitment :-)
smithy
Al.
smithy
One's from Dan @ DTA :confused1:
Edited by PhilP
GTR ones then mate. The 350z brackets only come from the US.
I don't think Alan realised you were using stock calipers with your brackets.
Smithy
best speak to krsmayo as he had that setup...
Hey Joel,
Does here still visit here? Ain't seen him on here for a while. I will pm him and if i get no joy, can you text him for me and ask? (That is, if you have his number lol).
Cheers buddy,
Al.
I dont know if this is any help, but here are a few pics of my work today, fitting some Brembo calipers, you can see the bracket that needs to be inplace to take the larger units.
Edited by daZvert
Looks the same as krsmayo's brackets. Got the pics saved, cheers matey.
Al.
Al.
That coz they were his, AND I didnt know!! :yes:, you have just steered me to his thread on how he fitted them, Thanks Bud
Daz
Did you fit evo calipers? If so, what discs have you fitted/going to fit?
Cheers matey,
Al.
Cheers matey,
Al.
Exacly the same as krsmayo`s bud, I bought the lot from Mad-max(He purchsed krsmayos car), they are evo brembos and 350z discs, I`ve not actually fitted them yet as i didnt have the longer bolts to go through the bracket into the caliper :sad:
Daz
Thanks guys!!
Anyone got a set of 350z discs for sale!! LOL!!
Al.
