What are you doing to the Z next?
I know lots of Zs don't really see the roads this time of year, and others are in daily use. But what are you doing to yours right now, what are you fitting next etc etc? Come on get typing :clap:
For me, tomorrow, I'll be taking the front bumper off and fitting my ARC intercoolers, fitting a splitter to the bumper before it goes back on, then fitting a few interior gadgets in the shape of an Apexi RSM and SAFC :thumbup:
  • Replies 41
  • Views 1.7k
Dont you want an R35?????? :yes: I`ve got a whizzer and i can cut the roof of for you!!:sneaky2:
I'll hold you to that Darren :flowers:
not the roof chopping thing lol :blink:
What next for my ZX?
Nothing - other than driving it! I haven't used it for a couple of weeks so I hope to take it down to Beaulieu tomorrow.....
Richard:thumbup1:
bit of tweaking in timing to do ad iam chasing 500 whp )) and fiting my dual hks clutch ,new oem alternator loom and ordering bde sprocets , fitting them too ..cant wait ..
Edited by mikael jackson
erm where to begin
picked up my new swb last weekend. starting tomorrow i will:-
remove the engine and give back to rigs
strip out engine bay and either clean up or repaint
remove all hicas associated bits and wiring loom
shotblast front cross member and repaint gloss black
repaint steering rack etc and fit to cross member with poly bushes
finish off engine-all new external gaskets, seals cambelt kit waterpump, repaint, new plugs, new sensors, new turbo elbows/decats with new o2 sensors, painted plenum, wire tuck, lightened pulleys etc
bolt up fidenzza flywheel with new bolts and rps clutch and attach new manual box with new rubber boots etc.
attach engine/box to cross member with new mounts to cross member and store.
strip underseal and tackle any rust
clean up all rigid brake pipes and paint up to protect/replace
zinc prime and stone chip underside
shotblast all suspension bits and repaint- replace all worn joints
refit engine and suspension
find new drivers wing- in metallic black if anyone has one
paint and fit 99 spec bumper
repaint hatch and fit new perspex strip- despoilered and de wipered
repair damaged paint on os 1/4 pannel and weld up airial hole
remove stone guard from below swage
restore all rubber trim bits
repaint scuttle and wipers
machine polish
retrim tweed in black alcantara
fit factory recaros
fit clutch pedal
mot!
enjoy car
planning on getting to a few shows this summer in it!!!
Sell it... LOL having a moment of weakness drove my M3 again tonight and id forgotten what iwas like!
Sort the brakes out the 300zx, they vibrate like Fck so not sure wether to just get some new discs for ebay standard size and see what they are like... also spotted these, seem cheap any good does anyone know?
http://cgi.ebay.co.uk/NISSAN-300ZX-Z32-FAIRLADY-VQ30DETT-FRONT-TENSION-RODS_W0QQitemZ160379096248QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item255756ccb8
Got the interior in bits retriming at the moment. Panels are done, doors still to do then fit new seat covers.
Have coverd the stereo suround and momo steering wheel in carbon fiber effect vinal going to do the dash vents as well as the switch surrounds on the doors.
With the trim off i'm fitting some sound dedaning material I got from e bay on to the back of the trim as well as onto the car itself.
Work for the near future, and thanks to temperatures of -14 degrees I now have leaks around the targas and boot so this will need fixing, the original spoiler has gone from bad to really bad thanks to the frost so that needs to go too.
Finally I want a new exhaust to try and get rid of the bloody drone which is present from 2k to 3.5k revs.
and once I get this lot done it will be MOT time then who knows.
Finished LED convesion to all bulbs including resistors inline.(what a pain in the ass that is)
Nearly finished fitting coilovers and adjustable tension rods, chamber arms, sway bars etc..Front & rear carbing braces done.
get the geo set up properly finally
Uprated rad and replace all coolant pipes, thermostat, fit chrome hard pipes.
Chrome balance bar & PAS pot still to do
Injen hard pipes to fit.
Fit new side mounted IC's although don't fancy removing the non standard front nose section as it may mess up the paint work where it meets the front wings. While Im there remove ERG and maybe C/Canister.
Have wheels refurbished then new tyres.
After that start looking at having a re-spray early next year as well as looking at 555 injectors and a spare engine to start re-building next year to chase 500bhp.
H.
Thats what im doing at the min and imo it is by far the best colour combo you can have for a black car.
those wheels will be stunning :gunsmilie:
do you have pics of this combo
I'm currently starting to save for a recon engine, as mine is in the early stages of giving up :( but i gotta get a second car first
plus i still got my new wheels and spoiler to fit to the Z at some point this year :)
mines been off the road since october and have been busy removed the hicas and aircon at the mo fitting new wireing loom, nismo 555cc injectors, ecu,timing belt,loads of powdercoated stuff, s.s.split down pipes and japspeed decatts, Z1 hoses and water pipes, some polished bits and bobs white dials,99spec front bumper,flat nose panel tinted rear lights and centre panel and some other bits not arrived yet!;)
dan.:cool3:
Im just replacing my engine after a bottom end failure, fitting a sat nav, dvd cd player into center console and finally getting my standard wheels sent away to be redone. (if anyone knows a good place in scotland or northern england let me know)
Where to start?
http://www.300zx.co.uk/forums/showthread.php?goto=newpost&t=131802
The main things i still need to do:
- Get the brake pipes replaced
- Underseal
- Replace the subframe and rebuild the rear subframe.
- Complete HICAS removal
- Fit new side skirts, front and back bumpers
- Wire up PC and Double Din DVD player.
- Leather retrim
Im sure there's still more but i cant think of them right now
Got Jimmer from this forum fitting two secondhand turbos, and a thorough check over then its off for an MOT, then its down to the bodyshop to get the front end blown over as it covered in stone chips.
Then enjoy it for the summer! :D
Then sell it (hopefully) about September time.
Have you booked it in, his spanners don't get cold these days.:oops:
I'm not really sure what that means, but yes, its booked in with him.
In other words mate he is always super busy, as in his tools are so hot where he has work so much :)
