Pipe/hose for Air ducts
Hey guys
For those of you that have air ducts in place of the front fog lamps andalso have a pipe/hose etc connected to them leading to either the intercoolers
or front brakes;
a: What kind of hose/piping did you use and what diameter was it ( a pic of the type used would be outstanding )
b: how did you connect the hose to the ducts.
As always, any help greatly appreciated.
Maz
i used 3" flexi hose but, 2 or 2.5" will do it.
as for fitting the hose to the duct, it's only pushed on so the bumper can come off cleanly.
yo mark i recently changed my 2.5 inch to 3inch like you :D and its no longer underneath the car scraping on the road lol.
Cheers for that mate...that´s probably a better idea, just to slip it over to make it easier when removing the front bumper.
Where did you get the hose from ?...i´ve looked all over the place ( here in Germany ) and all I can find is the hard plastic stuff ..that looks far better.
cheers
Maz
cheers
Maz
theres loads of that neoprene piping on ebay...
I believe you joel, but what do you call it ? "neoprene piping" for example brings up 0 results in ebay for example
Joel, you´re a star mate..thanks
no worries chap...
i'd hold fire until jimmy gives you an idea of how much you'll need. i seem to recall that he needed just over 1 meter each side, i'm sure that the 2 meters he bought wasn't enough. it might be worth messaging the seller to enquire whether he can cut some to lengths of 2 x 1.5 meter ducts. he sells 500mm lengths so he could still sell the off-cuts, this will save on the hefty 60 quid price tag of 4 meters!
then again jimmys intercoolers are mahoosive so it has a big divert to take and his intakes for the brake duct are't in the foglamp ducts so you may be ok.
i bought 4metres in the end, was a bit of a journy round the intercoolers etc
yep, it all depends on what you have to trail it round, i would say 3 metres each side, that way you will have enough to play with and then some to do the rears with as well :)
yeah i got all my old 2.5 inch i could prob do the rears or make some ducting to the turbo housing or somthing, i have not decided yet.
