:clover:hi lads still having this problem , car starts fine , drives like it down on power , on stationery when i rev it , it backfires , should i check the crank angle sensor could this cause back fire , valve timing 100%
any ideas , could it be the two solenoids at the back of the inlet cams , or AFM , showing code 55 :clover:
