sick of the diff!
need to either fix the viscous one iv got.. (somehow) or an upgrade? (somehow)...... can you weld viscous diff's? or do i just get a poo'y s13 open diff and weld that up? 2way sound terrible, 1.5 would suffice - any ideas?
Whats wrong with yours ? Just get hold of a replacment stock Diff. Plenty about.
sure you could weld it but not worth welding it unless your going to be drifting.
if your just drifting it then a welded diff will be fine
can a viscous diff be welded though? there completely different inside
yes mate, viscous diffs can be welded. they weld the s14 turbo viscous diff's. iirc.
Just a thought, but lots of import cars come with uprated diffs already and the owners think the diff is knacked when in fact it is the normal whirrings and clunking of an uprated one?
yep and you can only tell by taking it apart. i doubt axlaw's diff has anything wrong with it but its just not locking as viscous lsd's are poo for drifting.
it was ok tonight, gonna change the oil in the diff just to see if things improve, what oil does the diff require?
85W-90 GL-5 Transmission Fluid
nice one
I think the vicous part of the diff is sealed so an oil change may not help
boooooooo!:hang:
You can get plate or quaife internals for the R200. I'm looking at using an R32 GTR R200 plate in mine but its not a straight bolt in fit.
casing issue or a flange issue?
