Where do these go??
Can anyone tell me where these wires connect to please? The one with the rubber gromet was on the passenger side under the engine but can't see where it goes to? The other two I think were on the drivers arch in the engine bay, are these to do with the HICAS as one looks like it connects to this?
Thanks,
Ant
The one with the rubber grommet goes to what i think is the oil pressure sender, it's on the side of the (ish) on the passenger side, the other 2 'I think' they are for the auto box, have you done a manual conversion? if not, they either go at the front corner of the wing, but could be on either side... HTH
Cheers for that Tudor. I have removed the stock oil sender as I have a aftermarket gauge and sender, so from what your saying I will no longer require this. I did have a auto but had a manual conversion done so this will make these redundent. All makes sense now :D
Thanks again Tudor.
Ant
Ant,, the bottom 2 plugs look like the connectors mounted just above the main fuse box on the l/h side of the engine bay maybe?
gettin close me old fruit...
Trying to get down there most days for at least a couple of hours. Really can't wait now :biggrin:
Cheers Bigh. Nothing is where it should be now which makes it more confusing lol. Those connectors I have are on the otherside to the main fuse box.
Cheers,
Ant
Edited by Ant_300zx
