Front suspension upgrade
Hi People
Just started ripping old suspension components off car to fit new components. i have the following to fit to the front :-
Adjustable camber arms
Adjustable Tension Rods
Energy Suspension Master Kit
Stillen Uprated anti-roll bars
Adjustable link arms
Tein Monoflex Suspension EDFC.
In the picture below:-
I have got the poly bush which fits where the yellow spot is.
Can you get new improved rubber/ polyurathane parts?
Can they be replaced?
Is it worth doing?
I have also got a set of 6 pot AP brakes to go on. What is the best way to remove the brake shield complete?
Is it welded to the hub?
I wondered if i cut through, where i have placed the RED dot then could prize it open, as long as it is not welded to hub.
All comments appreciated.
Regards
Kev
Wow, thats some list of upgrades! :bow:
Polybushes - splparts.com and Z1 and conceptzperformance have a long list of available bushes.
Bear in mind that most of your stock bushes are being replaced by your adjusable arms, however the bushes inside the hub are not. They can be replaced, but you will need to remove the lot and have the old bushes taken out using a Bushing press.
You dont have to remove that brake shield, it can be bend flat and out of the way.
Edited by Yowser
