Sticky req
A lot of posts go up asking which fluids are used in the Zed
I thought we could come up with a list of them to view at a glance.
Oil................ 10w 40
Manual gearbox EP90
Autobox ........???
Diff................???
Power steering.....???
And so on
What do you think
Allan
Sounds like a good idea to me (especially as I'm new to Zeds)
I have the manual as well Dave, was just thinking of everyday discriptions i.e 10w 40 and dextron atf fluid etc, not everyone can equate the API standards
but thankyou anyway :)
Allan
Excellent idea Allan. would be great as a sticky so people can view the recommened/best oils/fluids to use for the 300zx. Tech guys, get this in motion. Well done that man!!!!
Al.
Maybe Jeff as a pro can shed some light on what he puts in to various areas can help?
Allan
Allan
I quoted the manual becuase it has all the information required to compile the Info.
Oil................ 10w-40 Semi or Fully Synthetic
Manual gearbox 75W-90 GL-4 Transmission Fluid
Autobox ........ DEXRON ATF Fluid
Diff................85W-90 GL-5 Transmission Fluid
Power steering.....DEXRON ATF Fluid
Brake ....... DOT 3, 4 or 5.1 Brake Fluid
We could go into more detail on certain aspects...such as when to perhaps use a different engine oil (e.g High powered engine), or when to use a different gear oil (e.g syncro problems..etc) , backwards compatablity of Dexron and the (in)compatibility and superceedence of DOT fluids.....not sure how much Info people want ?
Edited by Yowser
you want it as one post and with a clear title, you need members to pm you and then you edit the thread, if it's allowed to be replied to it can become too complicated
if a member would like to compile a list i can sticky and close it so it doesnt get bogged down with crap
You are on the exact track Allan
lets get the facts right and then just make a single post with no replies avalible..
Just the plain facts only. I think this can stay open for comment for a while so we are sure the facts a correct.
Allan
