Seatbelts..... Can they be tightened??? both doors are SOOOO slow at retracting...
Antony
A quick tempory fix, is pull the belt fully out, then spray some silicone spray similar to wd40, but must be with ptfe, on the underside of the belt, and also the upper holder. This will make it retract a bit faster, if not remove the lower part of the panel, and clean and lubricate the mechanism, this will require rear seat removal and other bits.
Nice one Stu, Mine do this aswell, will give your method ago
Cheers.
Its the door belts and it frustrating as it gets caught in the door. Whats the best way to remove the door panel? Any easy to miss clips???
the screw that you have to lower the window to get to
best to search for a how to guide
[sIGPIC][/sIGPIC]
