January 17, 201016 yr Can anyone tell me how easy/hard it is to remove and replace the rear bumper? and likewise side skirts. Also any guides or tips out there? cheers in advance.
January 17, 201016 yr Rear Bumper - Remove rear boot trim, start with the centre piece and work outwards. All screws become visible as you remove the previous piece. - You willl then see the nuts&bolts holding the bumper on. About a dozen or so. - Also held on my plastic screws below the number plate and a metal bolt underneath just behind the rear wheels Skirts - Z does not have any Standard, so depends on how the aftermarket skrits are fitted. Usually screws in the door sill and held at the front and back by the archliner screws. May also be screws underneath. Can also be bonded on, and if thats the case you may have trouble removing without damaging.
cheers in advance.
