THE OFFICIAL`ish 300ZX WEIGHT THREAD
Hi Guys, after just having my manual conversion delivered, I thought it would be a good idea to start a thread to let peeps know the weight of individual items from the 300zx, It would make it easier for us to estimate the shipping costs!
I struggled to let the courier company know the exact weight of the parcel they were collecting for me, I guessed at 85kg for the full complete kit, eg manual box, flywheel, pedals, master & slave cylinder, prop shaft, some pipes and bolts, The company never asked for any more money so i assume the 85kg was a good guess.
Just to add, It cost me £46 for the courier company to collect my gearbox pallet from Essex and deliver to my door in Southport, not bad i thought
SO! I will start with a few weights and we could follow on and add as you wish.
TT Autobox (empty of fluid) 76kg
N/A manual box (empty of fluid) update tommorow when weighed
1 standard wing 3.2kg
1 standard gear knob 340 grammes
1 pair of standard rear lights 2.1kg
1 plenum with balance bar 12.2kg
1 standard alloy wheel with tyre 18.3kg
1 standard radiator 4.2kg
1 standard brake caliper 2.8kg
1 standard center rear panel 1.0kg
1 standard N/A flywheel
Edited by daZvert
  • Replies 28
  • Views 3.7k
cool, would be good if a few more peple joined in and put the rest of the weights on the thread
great idea actually! see if we can list every single item until we reach the weight of the car! :rofl: seriously though it would be really useful for people looking to put their Z on a diet.
Excellent!! If any mods need to edit any wording I have done, make it sticky or make it proper Official ,also any ideas, please go ahead.
I was hoping this was a good idea! :smartass:
I will add some more tommorrow too :wink:
DaZ
Stage I
Cargo Cover………………………………........ ......................... ...........5
Spare Tire, Jack, Wheel Chock’s, and Inflator Can…………………..…32
Rear Hatch Weight………………………………....... ......................... ..3
Driver Seat (61)àAftermarket w/ alum. sliders and bracket(25)…….…36
Passenger Seat (42)àAftermarket w/ alum. sliders and brackets(25).….17
Rear Tow Hooks………………………………........ ......................... .......3.5
PRVR System………………………………....... ......................... ............1.5
Center Support Bearing………………………………...……. ...…......….1
Stock Drive shaft (31)à 1 Piece Steel(17)…………..…….….….... .……14
Battery (45-50)à Light Weight Battery(15)……………………………..3 0-35
*(Also move to trunk, pass. Side)
Pre Cats (21)à Down pipes (14)…………………………….…..…..... ....7
Stock Cats(26)à Test Pipes Alum(14) SS w/ flex joints(17.5)…………..8.5-12
Flywheel(21)à RPS (12.5)……………………………........ .....................8.5
Under drive Pulley(11)à Lightweight Pulley(2)…………………………..9
Headlight Aimers………………………………....... ......................... .........2
Timing Belt Covers………………………………....... ......................... ......1.5
Fan Shroud………………………………....... ......................... ..................1
Apparently the Stock Air Box Weighs More Than an Intake………….…..5
……….TOTAL…185.5-194
Stage II
Window Washer Reservoir and all Associated Lines………………5
Cruise Control………………………………...... ......................... ...2
All 4 Strut Actuators (do you really use them?)……………………1.5
Black Tar Sound Deadening Material………………………………33
Rear Wipers………………………………....... ......................... ......3
AIV System………………………………....... ......................... ......10 ???
T-Tops (14.5)à Carbon Fiber(5)…..X2.…………………………. .15
T-Top Wind Blockers………………………………..... ..................1
T-Top Shades………………………………....... ......................... ...2
Fog Light Air Ducts……………………………..…...... .................2 ???
Light Weight Steering Wheel………………………………........ ...5 ???
TOTAL…79.5
Stage III
Front Carpet w/ Insulation Attached………………………………15
Rear Rug and Wooden Spare Cover……………………………….8
ALL Plastic Panels with their Insulation Attached………………..23
All Tweed and Carpet Covered Panels……………………………10
*With exception to those touching the Dash
*Also Doors are intact minus the AC ducting and Insulation
Misc. Insulation………………………………... ......................... ...5
Radio, Speakers and all Associated Wiring………………………..30
Antenna and all Associated Wiring……………………………….2.5
Rear Pressure Equalizing Vents……………………………….......1 .5
TOTAL…95
Stage IV
AC and Heater System in Car (located under dash)………………26.5
AC Condenser and Other Engine Bay Lines (in front of radiator)..10
AC Fan……………………………….......... ......................... .........5
The Idler Puller and belt for the AC….………………….............. .13oz (round up to 1)
Air Bag Controls in Car and all Associated Lines…………………6.5
Front Wipers………………………………....... ......................... ....5
EGR System………………………………....... ......................... .....5 ???
Carbon Canister………………………………..... ......................... .3 ???
TOTAL…62
Stage V
HICAS Removal and NA Power Steering System Install………….37.5
HICAS Eliminator weighs 2lbs
Remove Passenger Seat………………………………......... ...........15-20
All wires no longer in use if following Stages I-IV…………..……20
TOTAL…72.5-77.5
GRAND TOTAL….494.5-508 lbs
Stage VI
Escort FPR Doors (2+0Only)...……………………..... ...................50 ???
*(They only weigh 10 lbs a piece)
Speed Glass install for all Glass would probably drop……………..50-75 ???
TT Rear to NA Rear is supposed to drop a good……………………50 ???
Dash, Gauge Cluster Cover, Metal Bracket, and Din Panel…..........16
Door Skins………………………………........ ......................... ........10 ???
Your Soggy Ass Turbo Deck (I would never ditch mine)…………..10 ???
Carbon Fiber Hatch with Lexan from AMZ…………………………40 ???
Titanium Exhaust………………………………...... ......................... 15 ???
Install Lighter Fuel Cell………………………………......... .............???????????? ????????
Cut out sheet metal skin on rear hatch……………………………….??????? ????????/????
TOTAL…252-267
WOW!!!!! Nice one iguanapeluda, Thanks for ALL those, someone has took their time to list them!!
muchas gracias,
Daz
Stage I
……….TOTAL…185.5-194
Stage II
TOTAL…79.5
Stage III
TOTAL…95
Stage IV
TOTAL…62
Stage V
TOTAL…72.5-77.5
Stage VI
TOTAL…252-267
That's confused me tbh, what are they weighed in lbs,kgs,oz etc...
I think its listed in LBS, Not sure though?
Daz
that old list was from Mr. Duffers was it not?
I think....I remember that I copy some month ago in other forums...:shuriken:
Stage I
Cargo Cover………………………………........ ......................... ........... 2.3kgs
Spare Tire, Jack, Wheel Chock’s, and Inflator Can…………………..… 14.5kgs
Rear Hatch Weight………………………………....... ......................... .. 1.4kgs
Driver Seat (61)àAftermarket w/ alum. sliders and bracket(25)… 16.4kgs
Passenger Seat (42)àAftermarket w/ alum etc........................ 7.7kgs
Rear Tow Hooks………………………………........ ......................... .......1.6kgs
PRVR System………………………………....... ......................... ............0.7kgs
Center Support Bearing………………………………...……. ...…......…. 0.5kgs
Stock Drive shaft (31)à 1 Piece Steel(17)…………..…….….….... .…… 6.4kgs
Battery (45-50)à Light Weight Battery(15)…………………………….. 13.6kgs
Pre Cats (21)à Down pipes (14)…………………………….…..…..... .... 3.2kgs
Stock Cats(26)à Test Pipes Alum(14) SS w/ flex joints(17.5)……… 5kgs
Flywheel(21)à RPS (12.5)……………………………........ ..................... 3.9kgs
Under drive Pulley(11)à Lightweight Pulley(2)………………………….. 4.1kgs
Headlight Aimers………………………………....... ......................... ........0.9kgs
Timing Belt Covers………………………………....... ......................... ......0.7kgs
Fan Shroud………………………………....... ......................... ................0.5kgs
Apparently the Stock Air Box Weighs More Than an Intake………….…..2.3kgs
TOTAL… 85.7kgs
Stage II
Window Washer Reservoir and all Associated Lines………………2.3kgs
Cruise Control………………………………...... ......................... ..0.9kgs
All 4 Strut Actuators (do you really use them?)……………………0.7kgs
Black Tar Sound Deadening Material……………………………… 15kgs
Rear Wipers………………………………....... ......................... ....1.4kgs
AIV System………………………………....... ......................... .....5.5kgs
T-Tops (14.5)à Carbon Fiber(5)…..X2.…………………………. . 6.8kgs
T-Top Wind Blockers………………………………..... .................. 0.5kgs
T-Top Shades………………………………....... ......................... ..0.9kgs
Fog Light Air Ducts……………………………..…...... ................. 1kgs
Light Weight Steering Wheel………………………………........ ... 2.3kgs
TOTAL… 37.3kgs
Stage III
Front Carpet w/ Insulation Attached………………………………6.8kgs
Rear Rug and Wooden Spare Cover………………………………..3.6kgs
ALL Plastic Panels with their Insulation Attached………… 10.5kgs
All Tweed and Carpet Covered Panels……………………………4.5kgs
Misc. Insulation………………………………... ........................2.3kgs
Radio, Speakers and all Associated Wiring………………………13.6kgs
Antenna and all Associated Wiring………………………………. 1.1kgs
Rear Pressure Equalizing Vents………………………………....... 0.7kgs
TOTAL… 43.1kgs
Stage IV
AC and Heater System in Car (located under dash)……………… 12kgs
AC Condenser and Other Engine Bay Lines (in front of radiator).4.5kgs
AC Fan……………………………….......... ......................... ......... 2.3kgs
The Idler Puller and belt for the AC….………………….............. . 0.5kgs
Air Bag Controls in Car and all Associated Lines………………… 3kgs
Front Wipers………………………………....... ......................... ....2.3kgs
EGR System………………………………....... ......................... .....2.3kgs
Carbon Canister………………………………..... ......................... .1.4kgs
TOTAL… 28.3kgs
Stage V
HICAS Removal and NA Power Steering System Install………….17kgs
Remove Passenger Seat………………………………......... ...........15kgs
All wires no longer in use if following Stages I-IV…………..……9kgs
TOTAL… 41kgs
Stage VI
Escort FPR Doors (2+0Only)...……………………..... ...................23kgs
Speed Glass install for all Glass would probably drop……………..29.5kgs
TT Rear to NA Rear is supposed to drop a good…………………… 22.7kgs
Dash, Gauge Cluster Cover, Metal Bracket, and Din Panel…....7.3kgs
Door Skins………………………………........ ......................... .......4.5kgs
Your Soggy Ass Turbo Deck (I would never ditch mine)………….4.5kgs
Carbon Fiber Hatch with Lexan from AMZ………………………… 18.2kgs
Titanium Exhaust………………………………...... ......................... 6.8kgs
TOTAL... 116.5kgs
Grand Total Weight Loss = 351.9kgs
Weight of 2+2 Model 1600kgs - Weight Loss Program = 1248.1kgs
Weight of 2+0 Model 1490kgs - Weight Loss Program = 1138.1kgs
Thought putting it all into Kilograms would help us all understand the real Weight of all our parts!
What company did you get the gearbox from in essex? was it MJP?
Its a very old list from about 5/6 yrs ago, from somebody on one of the U.S forums, been copied and pasted all over the place ever since. Originally in Ibs and converted above to KG by Munny.
However unfortunatly....most of it is guesswork and way off !
Edited by Yowser
A few more,
N/A Flywheel 9.3kg
N/A Manual gearbox 60.1kg
N/A Prop shaft 7.1kg
Yeah i was just about to say its a load of guess work, most of its not very useful lol
That old list is a bit scrappy? Over the next few months i will make a tidy version and update the old lists with more accurate readings and probably make it indexed too
Daz.
I have lost over 150kg from my own car, everything removed/replaced digitally weighed. Its been a while but I will try and find time to dig it out and list it up.
Nice on Bud, I was hoping someone else would put a few weights up, If you do, i can put them in order and a nice tidy list for us all to use!!
Cheers Daz.
  • 1 month later...
I'm in the process of putting my Z on a diet... so thought it would be a good time to review this thread and add some measurements of my own,we could maybe get a new list put as a sticky? :thumbup:
Daz / Legrath - Did you get any further with your weights lists?
Edited by Baz
Nice one Baz, I will start adding some more again, Its just been too cold to go in the garage and start weighing frozen zed objects :no:, so lets get this going again:clap:
Daz.
I want to get some accurate weights for some of the above - in kg. Went to B&Q the other day and got some scales, the missus thinks they are for the bathroom lol. :lol:
I'll try and weigh all the spares I have so we have a good list, ideal for ideas behind weigt saving, postage costs etc.
under drivers carpet and under passenger carpet total weight 9-10 kg ...
ive also removed tar-drivers and pass . total weight 10 kg .
spare wheel and jack and first aid kit towing rope and triangle total weight .20kg
will try to remove rear passtar and trunk tar too .
does anyone knows where to get lexan glass ?.
Edited by mikael jackson
wheres this tar stuff? under the carpets?
I know where to get lexan glass from :D il post up the link when i get home.
