protoj · 10 hours ago 10 hr
I have a 300 degree fuel rail and was wondering does it matter which way the fuel flows round the rail?
The reason I ask is the hoses off the rail seems to sit better at the rear of the engine if they are crossed instead of connecting the way the standard ones connect?
Hope you understand my poor discription :tongue_smilie:
