What else to do with G/box off
Hey just wanted someone to check my list and add to it as im gonna be taking my gearbox off soon to put the exedy clutch and flywheel on. Just wondered what else was worth doing whilst the gearbox was off. Im already looking at doing the release bearing and oil change with the MT 90 oil that ive heard about. Im looking at putting on the nismo release pivot too is there any seals taht i should look to change with the access ill have. Cheers in advance
Marty
rear main oil seal, thats not a bad idea whilst the box is out.
Ditto, it's cheap and deffo a must when doing a clutch imo
smithy
I would also renew the rear water pipe to the turbo. Easy to get to while gearbox is off, and they are renowned for going.
egr removal and plenum water bypass while box is off, also replace clutch line with single braided line.
Worth replacing the heater pipes aswell as its so much easier with the box off
on changing the rear crank seal will i need to get a new pilot bushing as well just been reading up on the job. So far my list is
braided clutch line
crank rear seal
trans rear seal
nismo gbox mounts
release bearing
nismo release pivot
redline mt 90 oil
nismo flywheel bolts
exedy twin plate clutch
Any more to add to the list?
braided clutch line
crank rear seal
trans rear seal
nismo gbox mounts
release bearing
nismo release pivot
redline mt 90 oil
Good idea to change the pilot bush defo ;)
I also changed the gasket on the rear main housing, although others thought this is a bit overkill?
