recirc/bov/bungs sizes needed please :D who knows?
I need the OD size of the top pipe where the bung should go when fitting bov's in place of the recirc valves, obviously i want to buy a rubber bung to fit over the top of it. Yes i cant be bothered to measure it myself.. too cold....
I also need the OD size of the lower rubber pipe that comes from the intercooler pipe that goes onto the bottom of the stock recirc. not the actual metal pipe size as im reusing the stock rubber hose....
Thanks guys.
  • Replies 64
  • Views 1.9k
You mean these things?
YEah kinda like that but the other way round, they bung over the top of the intake pipe female ones if that makes sense lol
Ahhh got ya - like these..
Your gonna need to keep an eye on those as getting hot n cold will make them brittle and they will eventually crumble/fall apart Jimmy. :gunsmilie:
Try a solid rubber internal tapered bung like theses mat - gotta make sense if your pushing it on a track real soon. http://www.rapidonline.com/productinfo.aspx?tier1=educational+products&tier2=Science&tier3=Laboratory+Equipment&tier4=Solid+rubber+bungs&moduleno=73907
Check out GEX performance! On google and ebay, they have the cheapest priced alloy bungs available in 28mm and 34mm! I've just bought 2 of each and it was 25 pounds posted :)
omg £25 for a COUPLE OF BUNGS ahhhhhhhhhhhh not thanks not in this world.......
il stick with my 2 quid chair ends...
Well.. for 4 :p which is about right, 4 pounds or so per bung .. I've seen people charge a lot more :) Hehe but yes you probs right - good thinking on the chair bung front :D
I cant use the ally bungs as i ditched the rubber pipe so minemust be a rubber or silicon one to go over the big intake nipple. And btw the intake pipe will not get hot... just realised its the intake pipe about a foot from the maf so i doubt it will crumble and die due to heat this part of the system soesnt get hot ;)
Right, its all installed dumps nicely to atmosphere, BUT stillcant boost past 17psi even with the ebc set to 100% ahhh i give up anyone have any suggestions? am i missing something........ what are the possible causes?!?!
