Fuel Rail (High level) is ready at last...
- Replies 62
- Views 2.7k
- Created
- Last Reply
AndyGP 36 posts
Ant_300zx 7 posts
Andy Isherwood 3 posts
pixas 2 posts
Hi - Happy New Year to all - I have been rattling on about my fuel rail for what seems an age now, but I have finally got something finished and ready for my car!
Just to recap:
I wanted injector choice using top feed Bosch style injectors.
I considered the 300degree rails (and others) a poor solution (for me).
I wanted parallel fuel feed options.
I wanted to prevent thermally conducted engine heat from the engine warming the fuel delivery system.
I wanted to be able to change injectors easily without plenum removal.
I wanted a fuel rail that could grow with my engine as it changes and becomes more powerful. (This system is good for up to 1600cc injectors)!
I didn't want to have to modify my engine too much! (Just the lower plenum).
I promised some pictures so...
These are the fuel rails test fitted to the lower plenum which has the custom injector bungs fitted.
The bungs look like this:
Here you can see the rails with the injectors test fitted - on the bench so to speak:
This is what it's all about - 555cc RCE injectors, as used by many race teams - £35.00 each NEW 1000cc RCE injectors are £75.00!!!
A couple of shots of the rails attached to the lower plenum:
The rails are joined and held in place by two phenolic blocks (non heat transfer material) that are also holding two brackets that hold the rails down via 4 x new (upper plenum fixing) bolts. (they are going to get covered in Carbon Fibre probably so.. :thumbup1:)
Couple more shots:
