What spark plugs for higher boost?
Just need to know the name of the plugs i should be using if running higher boost, eventually 21psi. ive got stock plugs at the mo and i think they may be blowing out, as it starts to misfire off boost.
  • Replies 56
  • Views 6.4k
Yep, they're fine
Cheers John, the cars hesitating between 4-5500rpm at the moment so want to put some fresh ones just in case its those causing it.
