i want to get rid of the hicas and clean up a bit but would like to get rid of the TT pump and change it for a NA pump, can i just remove the tt pump and all the hicas pipes and gubbins and put a NA pump in? do i need anything else apart from a NA pas pot and a NA pas pump and bracket?
dan.:)
  • Replies 39
  • Views 1.4k
Pretty much yes that's it, obviously you'll need the lock out bar as in Z1's pic.
I removed the whole lot, all lines under the car everything.
Just 1 thing about swapping the pump over, generally as it's a slightly smaller pump, you have to adjust the bracket to make the pump sit forward a bit because many have reported their pulley belt not being "true" otherwise.
Dunnno if Z1 do this slight alteration or not if you were buying from them.
Nothing a grinding wheel in a local garage can't do if fitting for yer though.
cheers
smithy
Isnt it an option to remove the TT pump, strip the HICAS pump internals out of it and block off the holes?
That way it keeps the pulley in the correct position and you dont need to faff about with grinding brackets and all sorts?
cheers
smithy
thanks for the info, i am planning on getting the parts together myself and doing it so any more tips on what needs doing would be greatly appreciated.
dan.:)
that sounds an option, is it easier to fit a NA pump and a bit of fettling with the bracket?
dan.:)
Edited by dannzx
got a tt pump with hicas section removed for sale if your interested, straight swap for original pump no modding of brackets required.
I got that kit from Z1 and i had to change the pulley as it didn't line up as Smithy said. I had bought the Unorthodox Light Weight Pulley set and had to order a N/A pulley to replace the TT one. You get a N/A bracket with the pump aswell which is different to the TT one. Just something to think about.
Cheers,
Ant
is it all sealed up and ready to go straight on? how much delivered?
dan.:thumbup1:
(GREAT SMILIES:w00t:)
this is the way i did it . and it works no probs..
and its dead simple to do too..)
yep all ready to go mate,it was fitted to my z and was working as it should, only removed it because im fitting an electric pump. £40 posted
is the electric item lighter??
any pics please??
any pics please??
no its not any lighter im using it because i want to move power steering pump so i can get a straighter air supply to turbo's, no pics at the moment but im mounting it where the batteery would normaly sit.
ok . money wise ??
iirc pump cost about £60 second hand from a saxo, had to make up a couple of pipes to connect pump to original pipework and a bit of wiring with a relay to supply power pipes and wiring were al from stuff i had kicking about.
that sounds very interesting any chance of some pics and a update at some point?:cool2:
dan.:sneaky2:
one pic i found this was taken when i was working out pipework and brackets for pump , this shows where pump is located now .
will be starting a journal sometime soon showing all mods/work done to car over the last year.
look forward to it, may put this on hold then!:biggrin:
dan.:sneaky2:
you cant put a NA pump onto a TT engine, as people say the pulley doesnt line up.
ive got the TT engine, TT pump,
just blocked the take-off for the Hicas with a banjo bolt i beleive (as is high pressure?)
it would be good to use a power steering resivour from a NA, as the TT resivoiur has a take-off for the Hicas.....
this is the TT resivour, as you can see i have blocked off the pipe on the right that used to go to the Hicas
I found the PAS pump from my shorty when i was up at my unit the night.
Gonna give stripping out the HICAS stage, a go tomorrow at work.
You can put a NA pump on a TT, and there are no alignment issues !
You need the NA Pump, NA Bracket and NA Pot and new 3rib belt.
The NA bracket ensures the pump fits in the correct position.
Edited by Yowser
thats probably where i messt up, used the TT bracket & TT belt, didnt work.
ok i got the pas pump out, i am going to get the hicass out, got locking bar for rear got a NA pas pot (option for tt pump with hicass stuff blocked off or NA pump ect) now i had fun up garage taking out the hicass gubbins out from the front i deffo dont need any of it do i? or the electrics? it looks so nice and clean with it out spose i have to have power steering!lol
dan.:thumbup1:
wires to and from the hicas solenoid!!!! can i get rid of them and where do they come and go from?
dan.:tongue_smilie:
dan.:tongue_smilie:
people do remove the HICAS solnoid from the engine bay,
id imagein the electrical wires go from the PAS ECU (footwell)
then the hicas oil pipes go to the back of the car.
