Quick indicator???
My driverside indicator today as started flashing very quickly, Pass side is fine anyone got any ideas???
Cheers Craig
Cheers Craig
One of your bulbs on the offside has gone.
Simple fix, whack your hazards on, have a look which one has blown and replace it.
JOB DONE :D
ahh hadnt thought about that DOH!!!!!!:mac1:
Right the saga continues, changed the bulb last night and nothing. played about for a while and all of a sudden it started working. YAY then go out this morning and same thing front driverside indicator dead again, any ideas????
hi you,ve got a bad connection there then,check for corrosion or damaged loose wires
Thats what i thought, ill have a proper look tomorrow
hazard switch? If the mountings are broken inside, the switch doesn't always fully release and can cause all sorts of weird indicator problems - if you remove the switch from the pod and then turn your hazards on and off & the indicator still works, that's your problem...
Min did it a few years ago but it was intermittent so only found out when someone told me to chek the hazard switch.
Rich
mine too... i basically brayed the dash in mine until i fixed it... Turned out the hazard button was stuck in and me belting it go WTF is wrong with you jolted it back out.. lol
so did that just stop 1 light working???? as its only my front driverside indicator thats not working???:bow:
