Timing belt ??
I have just fitted a new belt with the rebuild the pulleys seemed fine with no play and they seem robust should i change them ??
any help i would be grateful
i have changed them as well. my mechanic recommended.
if you mean the ajuster and tension bearings then I would change them
if anything happens to them you could wreck your engine
so i better change them , it soon starts adding up all the bits that are needed
cheers lads for the heads up
