protoj · 1 hour ago 1 hr
Hi all,
Just wondering what people are using to create flash animated banners. I need to do a number of banners for various websites and am looking for a free/cheap software package. Doesn't have to do a lot of "flash" things. Will mostly be using fade in/out and moving left/right text.
Any feedback or links are most appreciated! :D
Have a good weekend!
Regards,
