splashguard
Do you mean an undertray??
It all depends on the style of the bumper. On mine for example its very easy like the genuine one its flat underneath. But if you have a veilside one then i should imagen you would struggle
o yeah you have silverstreak which has a stillen front on. So it will be designed to accept the undertray. So its and easy job :)
I'm sure I had one fitted to it before the engine build. At which stage I had the stillen front end. So all the bolt holes should already be there. You may just need to pick up some of the screw fixers (i.e. sqaure clips that fit over the holes in the bumper.
