Standard Front and Rear Speaker Fitments
Hi Guys,
I am upgrading my head unit so I need to pick some higher wattage replacement speakers for throughout the car. I am not looking for some fancy install - just to replace the stock cans with better ones that will fit in all the same spots. Don't want the time and hassle of building enclosures or screwing with the interior.
Can some one tell me what size all the current stock speakers in a JDM Series 2 LWB would be and am I right in saying there are just 4 speakers to replace ( 2 either side of the boot space and 2 more in the door cards) or are there some more tucked away somewhere??
Any info would be greatly received - especially if anyone knows the bolt pattern for each location.
Many thanks in advance - Cyrus
6.5" front (fitting varies from manufacturers I had fusions in the car when i got it were a straight replacement, vibes 6.5" had to be modded and so did the focal comps I have in now all were said 6.5") 4"x6" rears are all that are fitted stock some series have clarion amps to rears too under the 4x6's
Edited by 8ace
As for the 6.5 fronts you will get a better sound from a set of components. That is where the tweater is seperate from the mids.
