Hicas removal
Is there a kit you can buy? also anywhere where there are decent instructions on what to do?.
ย
Is that everyting you need? What bits do you remove in the engine bay? im not quite sure what are the PS bits and what bits are for the Hicas.
ย
ย
there is loads of info on here about this and think got some instructions somewhere!:)
ย
dan.:cool:
it tales you in the kit what you can get rid off.
ย
Most of the stuff behind the driver headlamp.
Sure I've read that you need to change the PS pump for an NA one if removing the system totally.
I read that somewhere as well, I did a search on here but could not find a set of instructions etc. I might jump in the technical manual to see what I can find in there but It will not show you what changes need to be made to remove it.
Sure you can just bypass it but if you want to get rid off stuff I think you need a n/a stuff
ย
sent you pm.
ย
dan.:cool:
I would reccomend the Driftworks kit - keep the TT power steering pump but read the article on doing the bypass and devaning/removing the stuff from the TT pump.
I have the DW kit and kept the TT pump and removed the hicas ecu, it will feel very different in a good way trust me ;)
