Boost control
Hi all,
The Z absolutly flies......sometimes, then it don't quite fly for a while. I make a few adjustments to the EBC, then end up back where I started, and it flies for a couple of days.
I'm thinking get rid of the EBC and go manual valve. Do you reckon this is a good idea, or am I being a muppet.
Hi all,
Yep!
Once an EBC is set, you should never really have a need to play with it.
Assuming it's working right, something else is loosing your boost pressure.
Deffo don't go manual if you have EBC.
Get it checked and set up properly before you end up in trouble.
smithy
Thanks Jeff,
Sounds like I'm opening a bottle of pop when I change gear so that would be BOV's I guess. I'd better start saving to have it looked at.
