clutch pedal refit
Can you put the clutch pedal back with booster in place been trying for hours cant get it past the top loom tryed it bolted to booster as well any tips thanks.
I tried both ways, took me a very long time as i remember, but ended up managing it with the booster and clutch pedal 'partially' seperated, than after a lot of back ache later, eventually it went home, i found you have to just have the two sections just together, so you have movement, but try and get the bolts only just into the pedal, very faffy indeed, but you'll get there mate.... HTH
thanks tudor good tip went 1st time with everything loose cheers.:)
have you got the vacuum tank/s too? I didn't, so i went to a scrap yard, and got off a primera, a vacuum tank, haven't got any pictures i'm afraid, but it's about a 4 inch sealed plastic cylinder, and came with a one way valve, for a fiver! I fixed the tank next to the battery, and ran a hose across the back of the engine, to the tank, and back to the booster, works perfectly, all for a fiver! As i read on here, without the tank, it can cause the pedal to pulsate, or even push it's self down whilst driving, also tho, i think you can get around this by using a couple of feet of tubing from the balance bar to the booster with a one way valve, but that might be quite untidy! Just a tip matey......
Fitted new matrix and metal pipes a new hoses in 2 days what a pig of a job all works ok had to snap the silly 8mm bolt which goes in between the 2 pipes throw the bulkhead got feed up with it .
i did mine with the dash in,
then i removed the dash after it :slap:
