pipe off and more problems HELP please
Another day another problem just had the right downpipe off to change the gasket as it was blowing and got a couple of problems need help on. As i was removing the O2 sensor wire i think i may off pulled off a pipe looks like vacuum advance for something. Im not too clued up on all the sensors so bare with me. It goes from the right rear of the engine to a sensor/valve in the centre rear of the engine see pics. If someone has a pic of where this goes or a good explanation ill be grateful as had a look under and over and couldnt find where it goes
2nd problem is i changed both turbos a couple of months ago and had major problems with the left with oil feed. Left is now sorted but as i have the downpipe off thought i would feel the right one and ive got play there and sounds deels like the bearings have some play up down not endfloat. Ive not really pushed the car since i put it back together but was playing round with the boost controller and got up to 14psi got mines ecu too. Is 14 psi safe with standard tubs? Just changed the oil too and used millers again so im reading about 40/50 psi when cold then down to about 30 psi when hot.
3rd problem is someone keeps drinking my brake fluid :( it is a problem that i have had for a while as when i check it the level is goin down. had a look at all 4 calipers and no leaks there so its gotta be between pot and calipers. Thing is i have looked for an oil patch and can never see one where it it all going :confused:
Any ideas on these will be great help against my struggle to keep her on the road but like everyone else im not giving up :)
Marty
is it one of your vac pipes that have come off the servo?
oh ok is the egr valve in the middle of the engine im sure i remember reading it is somewhere. Where does the other end go to???
Type in vacum pipes in the search there is a good pic off where all the pipes go.
Your brake fluid is possibly a leaking master cylinder... look under the master cylinder on the Servo and see if it's leaking on there, I've had that on 2 of the Zeds I've owned...
hth
Paul
hth
Paul
Thanks for that Paul will look tomorrow
Ok the egr solenoid is that on the right side of the master cylinder i remember seeing 2 solenoids down there
