Tasked with fitting a missing fan shroud the radiator top hose was removed but unfortunately instead of a nice water/ antifreeze mix running out this is what did, got to say it does not look good eh?
Jeff TT
Not by any chance a lady owner, who's really chuffed with herself for managing to top up the oil :smw:
Tut Tut :D
Jeff
:eek: :eek: question is - how was the running temperature? :D
Odd it seems to run just fine, some spendS required for the future me thinks.
Jeff TT
looks like it needs a new rad to
Yes, common fault with top hose outlet breaking up, new side header are available but some bigger issues to worry about unfortunately.
Jeff TT
When emptying my knackered engine, i have the same kinda thing from the rad, washed the rad through and it looks like rust once the water starts clearing, i also have what looks like rust on the old water inlet outlet pipes leading to the engine.
Cept, the coolant mix coming out the bottom of the rad when first emptying was a nice fluorescent green color (looked like predator blood to start with lol) then turned a nice rusty/chocolate brown)
Jeff TT
interesting..
do you know how much one would be Jeff and is it something that can be done easily?
The photo`s do not really show but its oil and water mixed slippy a hell and smells of burnt oil.
Jeff TT
interesting..
Not sure of current price exactly but last one was around £50+ vat per header, they come with a new rubber gasket and its a case of bending the retaining tags back and replacing the header and gasket and then bending the tags back.
Jeff TT
Nissan only part is it Jeff?
Yes, will get the part number of our system in the morning if you like.
Jeff
Part number is 21412-40POO for the Tank Rad Upper (Nissan name for it)
Part number is 21412E for the seal.
Jeff TT
ok mate.
Only because a guy i know has his Zed sitting on his drive because the rad has broken and moneys a bit tight for him atm. This could be some good news for him.
Thanks Jeff
I may have beautiful flowing locks, but I'm definitely not a lady
ooops :rofl:
