Bad earth, or something else...
Sorry guys going to get a lot of questions from me for the next for weeks, as I've now started on my 300zx now its arrived home yesterday,
Right i have a problem with my drivers side front light cluster, both lights turn on, but the front drivers side is very dim, both seem to be working just doesn't seem like enough power is getting to them, passenger side is working as it should.....ho you know what ill go get some photos and post them to show you what i mean..
Could be a crap connection or have a look at the relays in the large fuse box, brown one and a black one, Pull and check the spade connectros, may be a warning that one is going to go.
Change the lamp...it's usually the culprit. If that doesn't work, check the connections as mentioned.
Hmm 1 an a half year old seems to of played hide the memory card from daddy's camera, i would be out taking photos around about an hour ago,
Bulbs are fine, i can even change them over to the passenger side an they work flawlessly.
SYSTOMS
- dull beam
- Unplugging the square light, kills both (doesn't do this on the passenger side, full beam light stays lit)
- Full beam doesn't work on drivers side
- Spots still work on both sides
- Unplugging main beam light doesn't kill square light
Im thinking its a bad earth but only on the drivers side, have checked fuses in the bay, but they are fine, cant seem to get the relays out to check (i have rubber coated ones), is there a specific clip i need to get to: to remove them? or am i just going blind in my old age?
