auto box problems. help please
my auto box is slow in changing gear and if i boot it it hits the limiter for a second and then changes, could it have something to do with the exhaust being 4.5" and 5" exit so no back pressure? i topped up the a/t fluid yesterday and it took about 2 pints and there is a slight improvement. any help much appreciated cheers.
could be lots of things, have a search for autobox problems on here you'll find lots have had similar problems, usual recommendations is to change the oil and clean the strainer, you can do diagnostics have a look in the faq section also.
i have the same problems mate. mine also kicks down with very little throttle.
im sorting it by a manual conversion but id still like to know
mine kicks down ok.
think ill try the diagnosis if i can work it out lol it sound confusing
its not hard just write it down on paper and do it as you read it. unfortunatly mine was ok
**Post edited, Sorry mate i had to edit you're post as registered user's are not allowed to trade on the forum you need to subscribe in order to sell**
Thanks, Chris
Edited by ck300z
Registered user attempting to trade
wont be your exhaust mate...i had no exhaust on mine for several weeks a while back and it drove fine...if a little noisy :D
worth doing diagnostic first and then changing your gearbox fluid
does it do the same if you select power mode?
**Post edited in line with post 07**
Edited by ck300z
Edited in line with NotKen's post above
ill try it in power and see.
the light that it says is for the diagnosis is the o/d light on mine so what light will flash?
just spoke to a guy at zedworld (great bloke) he said to try tps too or take it to himm on saturday and he will have a look for FREE how nice is that
