Another interesting 300zx vs supra
I'm talking 1/4 mile now :D
Why is it that the 300zx struggles to get into the high 12's doing the 1/4 mile when a stage 1 supra ie around 1 bar of boost on oem turbos can get into the 11's?
Both similar power, both similar weights, both RWD
Answers on a postcard :tongue:
  • Replies 36
  • Views 2.1k
But would it fit
not easily no and a second hand box is 2-3k
its all about tyres my mate done 12,8 in his lightly modified zx but run on toyo r888 and that made big diff ..
and yes look at this launch
That seems to squat perfectly :cool:
Very interested when I saw this post, very much doubt theres much stage one about that Supra.... To make a sub 12 run especially if that WAS at Santa Pod!! :eek:
Mighty impressed to say the least if it is inded on stock twintubs!! He does have a lower trap speed so must be good in the launch and good gearing/changes.:cool:
My Brother has a Big Single (mk4) Supra, and it's currently making making 661bhp (Fly) @ 20psi, his best time @ Pod (though with few boosting issues) so far is 12.1 on road tyres -Don't get me wrong he will get those sub 12's when the boost problem is fixed and more so on drag radials But here is his spec sheet and it's far from stage one!!
'ENGINE:
*hks 3.1 Built Block
*HKS Stainless steel head gasket
*ARP Head studs
*NGK Racing plugS > heat range 7
*Garrett GT4088R (special ball bearing turbo-known in japan as blowzilla)
Turbo with a 1.06 A/R, T4 style divided inlet flanged turbine housing with
3" V-Band outlet. Has a 4" inlet anti-surge ported compressor housing
Compressor:
-Wheel: 88mm w/ 54 trim
Housing Type: 4.00" inlet with anti-surge
Turbine:
-Wheel: 77mm w/ 84 trim
-Housing A/R: 1.06 A/R
-Housing Style: Standard T4 divided inlet w/ 3" V-Band outlet
-Oil Cooled
Using boost logic oil line return and feed kit with water cool by pass
*BOOST LOGIC Turbo Blanket
*50mm GREDDY External Wastegate with screamer pipe/dump tube
open feed straight off the turbo
*GREDDY High flow T4 Ceramic Anti-heat coated Manifold (wrapped also with FENSPORT heat wrap)
*GREDDY Type C 50mm external wastegate
*GREDDY screamer pipe
*TIAL 60mm Blow Off Valve
*REDLINE Water Wetter
*POWER ENTERPRISE Mag 2 oil filter
*TTC Performance Billet Aluminum Upper Shock Arm
*GREDDY Lightweight accesory Pulley Kit (alternator, the power steering, & the water pump pulleys)
*POWER ENTERPRISE Super Strong Kevlar serpentine (accessory pulley)
*POWER ENTERPRISE Super Strong Kevlar timing belt
*TITAN MOTORSPORT adjustable Cam Gears x2 (exhaust and inlet gears)
*FLUIDAMPR hymonically balanced crank pulley
*MOBIL 1 Tri Synth. Motor Oil 10w 30
*K n' N Oil Breather Filter x 2
*POWERHOUSE RACING Timing Belt Tensioner Bracket
*SARD oil dren/Drain Bolt
*GREDDY 1.3 bar oil cap
*GREDDY 1.3 rad cap
*ENVY Chrome hard upper rad pipe
*ENVY Chrome rad clamps
FUELING:
*WALBRO 255 a litre 'gss' 342 Fuel pump
*800cc SARD (hi imp.) Injectors
*AEROMOTIVE Fuel Pressure Regultor
*P.H.R fuel pulsation bi pass dampener
*SARD High flow Twin Feed Fuel Rail
EMS/STANDALONE/UNITS:
*LINK g3 lem pro standalone ecu
*LINK 3 bar map sensor
*HKS Turbo Timer
*AEM 'tru boost' Standalone Boost Controller
*Air Fuel Ratio guage
*GREDDY Boost guage
EXHAUST:
*Full custom exhaust System with 3.5" bore
*5" slash cut tail
*Full twin de-cat
GEARBOX/DRIVE:
6 speed manual
*TRD uprated solid transmission mount
*TITAN MOTORSPORT Stainless steel clutch line kit
*RPS 'Max' 6 Puck with sprung hub Clutch
*RPS Segmented lightweight 14lb Flywheel
WHEELS/TYRES:
*16" J-spec Mkiv Supra Alloys with BFG Drag Radial tyres (rears for drag)
*16" 300ZX Alloys with BRIDGESTONE S-02's all round (set of 4 r16/45/245 for track)
*18" 'LENZO' Alloys with 255/35 GOODYEAR 'eagle f1 gsd3's'
BRAKES:
*GOODRIDGE Braided lines for the rear brakes
*STOPTECH Front 14'' Big Brake Kit with slotted rotors featuring 355x32mm floating directional rotors
with 7075 T6 Billet Aluminum hats,
ST40 four piston high performance calipers
*Front stainless steel DOT compliant brake lines
*AXXIS Ultimate ceramic brake pads.
*CHRIS WILSON (fast road) Pads and Discs (rear)
with GOODRIDGE Braided Stainless Steel Brake lines
*Motul 600 Brake Fluid (dot 4)
CHASSIS/SUSPENSION:
*TEIN Coilovers 'type h.a tarmac' spec-Fully Adjustable
*VEILSIDE Front Strut Brace
*CUSCO Rear Upper Strut Brace'
I won't put his Exterior/interior bits----------Must say though, would REALLY love to see more 300's do the 1/4!!!! C'mon zedders!!!
(Did see an awesome white beasty at Snetterton Modified Live-which I'd never heard of/seen before-'whiffbitz'???)
Just read that and it does appear to be mvery minor mods, WOW!!! Very very impressed, though I didn't think the times woulda been at Santa Pod, even still thats pretty amazing....
i like the Z, but you gotta love the 2J. have you sen the power the stock internals can handle?
lets not all be biest as were on here, but i think the Supra is a better car than the Z :x:
it is (not in looks by a long way) because toyota had the zed to work from without the zed the supra wouldn't have been the car it is, this is a know fact and is stated in many write ups
and now you may leave.
seriously, I don't really care which is faster/better, I bought a Zed cos they look so good!
Edited by phill82
i dont think that is correct,
the Z has been around since the 60s,
and the Supra has been around for quite some time aswel! not just the mark4/JZA80 vs the Z32,
the supra has developed itself for about 20 years, (when they used to call it the celica supra)
djpone is correct, the Supra Mk4 release was pushed back a few years when the Z32 hit the market.
im talking mkIV supra Vs. Z32 as i think this is what this thread was about
ok sorry,
just wanted to say that the supra has been around for ages, maybe the a competetor to the Z, but dont think it copied the Z, developed itself :)
