October 9, 200917 yr apparently check wile running in N, but just wondering should it be up to temp or cold when i check the level.
October 9, 200917 yr Check it at normal running temp (take it for a drive). Get someone to sit in with there foot on the brake select Drive 'D' then check level
October 9, 200917 yr just like the engine oil dip stick really but hard to see cause the fluid is red or should be lol. just take your time and dip and wipe a few times.
October 9, 200917 yr ok its a running engine....select all gears slowly inc reverse...foot on brake of course....then back to neutral handbrake on and then pull the up stick...better if warm first
October 9, 200917 yr ok its a running engine....select all gears slowly inc reverse...foot on brake of course....then back to neutral handbrake on and then pull the up stick...better if warm first Thats better !
October 9, 200917 yr Check it at normal running temp (take it for a drive). Get someone to sit in with there foot on the brake select Drive 'D' then check level got that wrong didnt i :xxx: sorry about that must have been thinking of something else. http://www.300zx-twinturbo.com/cgi-bin/manual.cgi?list=ma&dir=&config=&refresh=&direction=forward&scale=0&cycle=off&slide=23&design=default&total=33
