Can a boost leak cause lumpy running, poor idle?
Recently fitted a boost guage, i dont think i have a boost leak but since my idle has dropped to about 650 from about 8 and its cut out twice when cold. It also seems very lumpy when i pull up at lights.
If it didn't do this before you fitted the gauge, then you have probably caused the problem. You'll have to check all your connections thoroughly and other connections in that vicinity.
