guys
before trying to fit these could someone tell me the 'A' measurement
i need to know if these will clear my 18" wheels or will i need some spacers?
any help much appreceated :)
What is the width and offset of the wheels? And what is dimension "A" from your drawing?
Mike
Mike
That is what i want to ask the guys who have these on there zed, i need them to measure dimension 'A' then i could see if my wheels would fit or space them out
HAve you allready got the calipers?
If so simply do this as I did and you will see if they clear.
evo brakes can fit under 17's so unless your wheels have a very high offset then you will be fine bud
ah thanks guys i was a little worried as the calipers are quite close to my spokes on the alloys i have'nt bought the calipers yet just checking to make sure i can still use my alloys
Circumference wise you'll be fine as you can see by mine under 17's but you may have to space off for spoke clearance depending on offset. I did.
