- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Right guys i have been thinking about Performance of the Zed and mods in the Future.... So what is one of the main Restriction for power on our cars.... INJECTORS!!!! As turbos max out at 18psi, what holds you back is our Injectors which max out at 14.5psi! So next size up = 555cc injectors which seems excessive on an slightly Upgraded setup and requires specific chip for fuelling etc etc!And have you seen the f**king price of them!! Robbery or what!!
So having a browse i see that the 350z (not a typo) injectors you can have Nismo 440cc injectors for around 1/2 the price for a set of some (300zx)Nismo 555cc injectors! Now as the injectors are only a small amount bigger a new chip shouldn't be necessary and only a small amount of fuel adjustment needs to be made on the map as flow rate is higher! This will enable people to run Higher boost if wanted without fear of DET!
Now from what i can see the Injectors look the same and i dont know if they would fit (Perhaps) and what would be the main difference between this 300z set and the 350z set?? I know older injectors had Lower Fuel pressure and large Spray from a large 'exit hole' where'as newer injectors have a Higher pressure but with more 'exit holes' thus creating a Better and more even spread of Fuel. (Lazy Excuse time) In a rush for work so dont have time to look up Fuelling spec as per 300z and 350z but i dont see why we have to follow the same s**t as everyone else. (no offence to Crowd followers) but would anyone know of what modifications would be needed to make these injectors work. Seeing as i cant find anyone whom has done it before this could be a new adventure.
I only query as when helping my friend on his car we used different injectors on his car which were slightly bigger and were High impedience which worked out better and provided him sufficient fuelling and slightly better performance (he upgraded from 270cc to 330cc)
Just feel that people need to expand their minds on what Modifying is all about and not just all falling into the category of Show and Shine boys :rant::rant::rant:
Hopefully this maybe of use to some people and the Tech Heads can have a good ol think!
Many thanks and will have a peek after work after 11pm :(
