Clutch Master Cylinder Required
Hi all, has anyone changed their clutch master cylinder? The clutch line connects to the bottom of my cylinder but every cylinder i've looked at on the net has the clutch line connect on the side.
Has anyone else had this problem?:headvswal
I got a seal kit bud, replaced the seals inside, easy job :)
just getting the cylinder out thats a bit akward
Did your cylinder have the clutch line connect underneath? Is fo, where did you get the seal kit from?
